查看: 9877|回复: 2
[陆军装备] [开盒简评]红星(3694)-1/35 苏联T-28中型坦克开盒
发表于 2019-3-20 13:48:39 | 显示全部楼层 |阅读模式
1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg 15.jpg 16.jpg 17.jpg 18.jpg 19.jpg 20.jpg 21.jpg 22.jpg 23.jpg 24.jpg 25.jpg 26.jpg 27.jpg 28.jpg 29.jpg 30.jpg 31.jpg 32.jpg 33.jpg 34.jpg 35.jpg 36.jpg 37.jpg 38.jpg 39.jpg 40.jpg
Friends!
While we complete your orders with model T-28 from Star It's time to peek into the box!
We Present to your attention the review on novelty Stars-the average tank T-28 and our appetizing bonuses from a set of pre-order!
The tank Itself was developed in the early 30s of the 20th century and at the time of its creation could rightfully be considered one of the best medium tanks. The multi-Byte layout is quite quickly old archaic, but the rest of the tank was characterized by good characteristics and lasted in the serial release until 1940, constantly changing and modernizing. of Course, by the end of the 1930s it was outdated, and the war with Finland revealed a lack of reservations and other shortcomings. Nevertheless, these machines managed to take part in the Great Patriotic War, and for our tank building T-28 was a landmark machine.
Set-Completely new Star development. While creating the model T-35, the Star mentioned the T-28 measurements in the TMVC (the T-28 and T-35 towers are the same) and many believed in the rapid release of the T-28 model. They were right. Since the basis was taken by a car from the CENTER-then and the model is a tank of the 1934 year, which subsequently modernized at the Kirov plant and received features of machines of the 1936-37.
The Box in the corporate style of the Stars-soft color box with a dense box of thick cardboard inside. The front side of the box is decorated with boxing-art in the performance of Andrei Zhirinovsky, on the back side-an example of model execution in ready form. This time, one box is easy To get from another.
The items Themselves are packaged in a common package, transparent details, decals and nylon mesh are packaged in an individual package. The Details in the box lie tight, do not hang. In General, the box should be without problems to survive the possible hardships of postal shipment.
Instruction in the corporate style of Stars, with a couple of variants of model Assembly. There are minor errors, with the confusion of the variative stages of the assembly.
Color Scheme colour, with the instructions of flowers on the palette of Master-Akril and Tamiya. There are four color Options, including camouflage and winter machines.
The decal Itself is printed by the company  "Hippo " and is distinguished by good quality. There are no Shifts of colors and steps. The small inscription with a slogan for a winter variant of colouring perfectly reads.
Except for decals in a transparent package there is a Kappronova Setochka for imitation of details on MTO and a pair of transparent glasses for headlights.
And of course-castings.
10 Frames of green plastic. The plastic Itself is soft, well processed and glued, but quite strongly dissolves super-flowing adhesives, be careful.
Casting is good, but there are flaws in the form of ducklings. They are found on the side of the hull, in the area of internal antennae. In other things these ducklings will not be visible after assembly. Just a couple of utazhin is on the fastening of tow ears on the stern, here It will be necessary shpaklevka.
The rest is ok. The Marks from the joint of molds are not noticeable, there are no offsets. On a number of casts there are whitish divorces from ingress of moisture in Polysterol, but on physical properties of casts it does not influence and disappears under a layer of a primer.
Detalrovka pleases the eye. The Smallest welds, bolts and rivets, a very detailed chassis detailing and the ability to remove the screens and show this splendor.
Even the gun barrel is hollow and with the advers inside!
The tracks are Polunabornye, with a good relief and a protis on the upper branch of the caterpillars.
The Grate above the radiator on the MTO from the inside is highlighted by the expansion, which makes it easier to replace the photopoisonous part when necessary.
On the other hand for newbies the model will be challenging, due to the large number of details and small things. AT assembly It is necessary to be careful, that would keep an invoice of welded seams and etc.
In General, the set makes a great impression and pleases attention to detail. Not for nothing in the development of the model measured the real prototype. Construction of the model promises to be interesting!
And Let's not forget about our bonuses!
All customers who pre-order on the model receive a nice bonus: sharpened gun barrel and 4 machine gun, 3B paint and discount coupons for the next purchase and the upcoming set of Photopoisoning!
Consider the bonuses closer.
The turned trunks are made of brass. The gun Barrel has a more correct wall thickness than the native plastic part. In plastic caliber is rather 85-90 mm, and the barrel itself is thick.
The part of the plastic barrel with the part F7 will need to be cut Under the fitting of the sharpened part.
The turned barrels of machine guns are assembled from two parts. When installing on the model, it is best to focus on the plastic parts for proper installation of the turned trunks at the depth.
The Paint is packed in a transparent vial, similar to Vallejo banks, ZIP-Layout, etc. Inside-Acrylic paint, almost without odor, the consistency suitable for coloring and brush, and airbrush straight from the jar. If necessary-diluted with water. Pigment has a property to exfoliate, but it is peculiar to all paints. Before use-shake!)
Well, regular customers from the Club Armats get extra Bonuses!
Plates for parade tanks  "Stalin ",  "Zhdanov " and "Kirov ", parade flags, metal rope and washed out paint  "lime " for winter camouflage.
Nameplates with names of party figures are molded from molded plastic. It is Enough simply to cut them from a litnik and to install on a model. Inscriptions  "Andrey Zhdanov " It is better not to cut on a contour, and carefully to cut off a pilkoj from a basis or to waste their substrate on Emery paper.
Flags are printed on thin paper. For installation of them on a model it is necessary to cut out halves of a flag on a contour and to glue on PVA, and then to glue to a TREE. As a pole it Is best to use metal tubes/rods or drawn sprat.
The Cable is made of copper and has a realistic texture. The Length of the line is enough for two cables. Kokushi should leave plastic, having pasted a cable in them.
The Washed-out paint  "lime " For winter camouflage is applied on top of the main color and washed off with water. No special liquids or hairspray Are needed. We will soon devote A separate post to this paint.
To summarize, I want to thank the "Star " for the chic T-28!
And we have tried to make this set more interesting and pleasant, diversifying the choice of prototypes and adding model of pleasant bonuses!
Development of photopoisoning in full swing!
Stay with us and thank you for your attention!
原文
Друзья!
Пока мы комплектуем ваши заказы с моделью Т-28 от Звезды самое время заглянуть в коробку!
Представляем вашему вниманию обзор на новинку Звезды - средний танк Т-28 и наши аппетитные бонусы из комплекта предзаказа!
Сам танк был разработан в начале 30ых годов 20-ого века и на момент своего создания мог по праву считаться одним из лучших средних танков. Многобашенная компоновка довольно быстро стара архаизмом, но в остальном танк отличался хорошими характеристиками и продержался в серийном выпуске до 1940 года, постоянно меняясь и модернизируясь. Конечно к концу 30ых годов он устарел, а война с Финляндией выявила недостаток бронирования и другие недостатки. Тем не менее эти машины успели принять участие в Великой Отечественной войне, а для нашего танкостроения Т-28 и вовсе оказался знаковой машиной.
Набор - полностью новая разработка Звезды. Еще при создании модели Т-35 Звезда упоминала о обмерах Т-28 в ЦМВС (башни у Т-28 и Т-35 одинаковые) и многие верили в скорый выпуск модели Т-28. Они оказались правы. Так как за основу была взята машина из ЦМВС - то и модель представляет из себя танк выпуска 1934 года, впоследствии прошедший модернизацию на Кировском заводе и получивший черты машин выпуска 1936-37 годов.
Коробка в фирменном стиле Звезды - мягкая цветная коробка с плотной коробкой из толстого картона внутри. Лицевую сторону коробки украшает бокс-арт в исполнении Андрея Жирнова, на тыльной стороне - пример исполнения модели в готовом виде. На этот раз одна коробка легко достается из другой.
Сами детали упакованы в общий пакет, прозрачные детали, декали и капроновая сеточка упакованы в индивидуальный пакет. Детали в коробке лежат плотно, не болтаются. В целом коробка должна без проблем пережить возможные тяготы почтовой пересылки.
Инструкция в фирменном стиле Звезды, с парой вариантов сборки модели. Есть мелкие ошибки, с путаницей вариативных этапов сборки.
Схема окраски цветная, с указаниями цветов по палитре Мастер-Акрила и Тамии. Вариантов окраски целых четыре, в том числе на камуфляжную и зимнюю машины.
Сама декаль напечатана фирмой "Бегемот" и отличается хорошим качеством. Смещений цветов и ступенек нет. Мелкая надпись с лозунгом для зимнего варианта окраски отлично читается.
Кроме декалей в прозрачном пакете лежит капроновая сеточка для имитации деталей на МТО и пара прозрачных стекол для фар.
И конечно же - отливки.
10 рамок из зеленого пластика. Сам пластик мягкий, хорошо обрабатывается и клеится, но довольно сильно растворяется супер-текучими клеями, будьте внимательны.
Литье хорошее, но есть огрехи в виде утяжин. Они встречаются на бортах корпуса, в районе внутренних усилений. В прочим этих утяжин не будет видно после сборки. Так же пара утяжин есть на крепеже буксирных коушей на корме, вот тут понадобится шпаклевка.
В остальном - все ок. Следы от стыка прессформ малозаметные, смещений нет. На ряде отливок есть белесые разводы от попадания влаги в полистерол, но на физические свойства отливок это не влияет и исчезнет под слоем грунтовки.
Деталировка радует глаз. Мельчайшие сварные швы, болты и заклепки, очень подробная деталировка ходовой части и возможность снять экраны и показать это великолепие.
Даже ствол пушки полый и с нарезами изнутри!
Траки - полунаборные, с хорошим рельефом и провисом на верхней ветви гусениц.
Решетка над радиатором на МТО изнутри выделена расшивкой, что упростит замену на фототравленую деталь при необходимость.
С другой стороны для новичков модель будет сложной, из-за большого числа деталей и мелочевки. При сборке стоит быть аккуратным, что бы сохранить фактуру сварных швов и тд.
В целом набор производит отличное впечатление и радует вниманием к деталям. Не зря при разработке модели обмеряли реальный прототип. Стройка модели обещает быть интересной!
И не будем забывать про наши бонусы!
Все покупатели, оформившие предзаказ на модель получают приятные бонусы: точеный ствол пушки и 4 пулемета, краску 3Б и скидочные купоны на следующую покупку и грядущий набор фототравления!
Рассмотрим бонусы поближе.
Точеные стволы выполнены из латуни. Ствол пушки обладает более правильной толщиной стенок, по сравнению с родной пластиковой деталью. В пластике калибр скорее 85-90мм, да и сам ствол толстоват.
Под установку точеной детали нужно будет срезать часть пластикового ствола с детали F7.
Точеные стволы пулеметов собираются из двух деталей. При установке на модель лучше всего ориентироваться на пластиковые детали для правильной установки точеных стволов на глубине.
Краска упакована в прозрачный пузырек, похожий на банки Валлехо, Зип-Макета и тд. Внутри - акриловая краска, почти без запаха, по консистенции подходящая под окраску и кистью, и аэрографом прямо из банки. При необходимости - разводится водой. Пигмент имеет свойство расслаиваться, но это свойственно всем краскам. Перед употреблением - взбалтывать!)
Ну а постоянные покупатели из Клуба Арматы получают дополнительные бонусы!
Таблички для парадных танков "Сталин", "Жданов" и "Киров", парадные флаги, металлический трос и смываемую краску "известка" для зимнего камуфляжа.
Таблички с именами партийных деятелей отлиты из литьевого пластика. Достаточно просто срезать их с литника и установить на модель. Надписи "Андрей Жданов" лучше не вырезать по контуру, а аккуратно срезать пилкой с основания или сточить их подложку на наждачной бумаге.
Флаги напечатаны на тонкой бумаге. Для установки их на модель нужно вырезать половинки флага по контуру и склеить на ПВА, а затем приклеить к древку. В качестве древка лучше всего использовать металлические трубочки/прутки или тянутый литник.
Трос сделан из меди и обладает реалистичной фактурой. Длинны отрезка хватает на два троса. Коуши стоит оставить пластиковые, вклеив трос в них.
Смываемая краска "известка" для зимнего камуфляжа наносится поверх основного цвета и смывается водой. Не нужны никакие спец-жидкости или лак для волос. В скором времени мы посвятим этой краске отдельный пост.
Подводя итог хочется поблагодарить "Звезду" за шикарный Т-28!
А мы постарались сделать этот набор еще интереснее и приятнее, разнообразив выбор прототипов и дополнив модель приятными бонусами!
Разработка фототравления в самом разгаре!
Оставайтесь с нами и спасибо за внимание!
 楼主| 发表于 2019-3-20 13:57:02 | 显示全部楼层
41.jpg 42.jpg 43.jpg 44.jpg 45.jpg 46.jpg 47.jpg 48.jpg 49.jpg 50.jpg 51.jpg 52.jpg 53.jpg 54.jpg 55.jpg 56.jpg 57.jpg 58.jpg 59.jpg 60.jpg 61.jpg 62.jpg 63.jpg 64.jpg 65.jpg 66.jpg 67.jpg 68.jpg 69.jpg 70.jpg 71.jpg 72.jpg 73.jpg 74.jpg
Armata赠品
75.jpg 76.jpg 77.jpg 78.jpg 79.jpg 80.jpg 81.jpg 82.jpg 83.jpg 84.jpg 85.jpg 86.jpg 87.jpg 88.jpg 89.jpg 90.jpg 91.jpg 92.jpg 93.jpg 94.jpg 95.jpg 96.jpg
关于赠品中树脂件与水贴红色海报用途,详见翻译
 楼主| 发表于 2019-3-20 14:50:13 | 显示全部楼层
GMT+8, 2025-7-2 08:06
